QLED TQ32Q50A 4K Smart TV 2023
1326 membres
"Ecran QLED FHD 80 cm (32"") - Quantum Dots Compatible Google Assistant et AirPlay 2 Quantum Processor Lite - Smart TV 3 HDMI - 2 USB"
Enregistrement sur hdd
Impossible d'enregistrer une émission. Seule l'option visionnage apparaît.
Merci de vos réponses
Consulter la réponse à la question Enregistrement sur hdd
  • Extrait notice de cette TV :
    Recording Programmes
    Record a current or upcoming programme using a USB device instead of a video recorder.
    This function may not be supported depending on the model or geographical area.
    Read all precautions before using the recording feature. Refer to "Before Using the Recording and Timeshift Functions" for
    more information.
    You can record only the programmes that are received through an aerial.
    The appears next to the programmes and channels scheduled for recording.
    If you go to Live TV while no USB device is connected, the Schedule Manager screen appears in place of the
    Recordings screen.
    Using the instant and schedule recording options from the Guide screen
    • Instant Recording
    Select a live programme from the Guide, press and hold the Select button, and then select Record from the
    pop-up menu to start recording immediately.
    • Schedule Recording
    Select a programme scheduled to be broadcast, press the Select button, and then select Schedule Recording to
    set up a scheduled recording of the scheduled programme.
    Using the instant and schedule recording options while watching a programme
    • Instant Recording
    If you select Record after pressing the button twice, and then press the Select button or after pressing the
    button once while watching a broadcast, recording starts.
    Press the Select button while watching a programme to display the programme info window. Use the left or
    right directional button to select a scheduled programme. Press the Select button, and then select Schedule
    Recording to set up a scheduled recording of the scheduled programme.
